Topic: UCX Using ADAT ins with Logic Pro
I Cant figure out how to route the TotalMix to get the ADAT ins to show up in my Logic session.
I see the input is working in TotalMix but cant get this to show up in Logic..
Please help!
RME User Forum → TotalMix FX → UCX Using ADAT ins with Logic Pro
Please help!
TotalMix is not involved with this. If you use FireWire for the connection, please check the Fireface Settings application. "Limit B" (bandwidth) should be set to "All Channels".
If this is already correct (or you use USB), then perhaps you missed something in Logic setup (active I/O channels?), or did not select the correct input on the track.
