Topic: Different Signals on SPDIF and LineOut possible (9632)
Hello all,
i`ve got a short question. Is it possible to route a different Signal to SPDIF out (for Singer Headphone) than to lineout? I`ve tried everything in Cubase to make this work, created a seperate Output to SPDIF and route Signal to spdif, but until now it was not possible to get there a seperated Signal to this SPDIF Output.
Or is it not possible that SPDIF IN and LINE IN and SPDIF OUT / LINE OUT are same, only different Format?
Thanks for your Reply.
Re: Different Signals on SPDIF and LineOut possible (9632)
All inputs and outputs are totally independent. Likely an issue of the Cubase configuration...
Okay, then i will have a closer look at that. Thanks for your reply.
