Topic: Is Direct monitoring possible using different input than output?
I want to go in to my HDSPe using an 8 channel preamp AES/EBU (Cranesong Spider,) and then monitor through a different device (Metric HAlo ULN-8)
What kind of audio delay am I lookin at? or is it true direct, simply in and out AES/EBU?
Thanks,
MR
Re: Is Direct monitoring possible using different input than output?
The delay in TM can be disregarded. The important delay is the sum of AD and DA delay caused by the converters. Around 2 ms.
thanks. what is "TM?"
TotalMix.
Thank you.
