Topic: AVID Venue Profile to Madiface & Protools
Does anyone have any experience connecting an Avid Venue / Profile console with the MADI option card to the Madiface portable i/o into a Macbook Pro and recording onto ProTools?
Would this work?
thanks for your help.
Brian
Re: AVID Venue Profile to Madiface & Protools
I can tell that this works perfect:
42 channel recording/playback/virtual soundcheck
Avid Venue with MADI option card - Macbook Pro - Sonnet PCI thunderbolt adapter - HDSPe MADI FX - LogicPro.
Not the same but I hope it helps.
Thank you for the reply!
Pro Tools will only see channels 1-32 of the MADIface, but otherwise it should work fine.
Thank you Jeff,
So... Even though theMADI spec is 64 channel at 48k it will only do 32?
Is there any way, short of a full blown PTs rig, to do a 48 track record?
Thanks for the help.
This is a limitation of PT, not of the Madiface.
You could record in other software, e.g. Reaper.
