Topic: Audiorail & ADI 648
Hi!
I´d like to connect a Preamp and and i/0 Rack to an ADI648, without having to plug / unplug ADAT optical all the time.
I could get an Audiorail as a cheap solution at the moment. It transfers 4 ADAT i/o to CAT5, so I would only have to conect a Network cable between the Racks. A second Audiorail Unit would be conected to the ADI648.
Since I heard about Problems with Divices using JetPLL in combination with Audiorail, I´m now a bit concerned about SteadyClock ... Did anyone try Audiorail with the ADI? Will it work? Or shall I look for and Appsys ADX?
Thank you!
