Topic: HDSP9652 + ADA8000 no sync
Hi all,
I just bought a used HDSP9652 PCI Card and I´m trying get it synchronised with a ADA8000 using 2 optical cables. No matter what I do it always shows "no lock" in SyncCheck and the time code isnt set (-- : -- : --). The playback sound is just a chaotic noise pattern and also when there is no playback it gives out high frequent crackles. I also tried to sync with wordclock but it doesnt change anything. When i move the optical plugs the crackling changes or the sound disappears at all. When i set the ADA8000 as master and Clock Source in the DSP settings to "ADAT1 In" the SyncCheck flips between "Sync" and "No Lock" in irregular intervals and the Clock Source flips between "ADAT" and "Internal". The ADA8000 status led says sync is locked in all positions (Slave WC, ADAT in, Master). Does anyone have an idea what could cause this problem? I am grateful for any help!
