Topic: HDSP 9632, SPDIF, ADAT and Win 7 64-bit
Hi, My two PCs are slowly on their way out after 10 years, both running XP, Soundscape Mixtreme cards connected to my Spirit 328 via TDif, with one PC also using the Spdif output so my mixdowns get recorded back into Cubase with the 328's spdif input.
My Mixtreme cards won't run under Windows 7 on PCs with more than 2GB or RAM, so I am look at the HDSP 9632 instead, to go into the 2 new PCs (when I get them). I just wanted to check that they would both work under Win 7 64 bit with lots of RAM  in each and also to check that I can connect via ADAT and Spdif at the same time, for recording my mixdowns back into Cubase via the spdif input on the 328.
Thank you very much.
All the best!
Clive
Re: HDSP 9632, SPDIF, ADAT and Win 7 64-bit
Yes to all.
Great, thank you very much Matthais, exactly what I was hoping for! smile
