1 (edited by SKL 2014-02-21 11:45:10)
Topic: HDSP9632 Analog outputs problem
i have an HDSP 9632 PCI used on 1155 i5 , H77 mobo with a pcie to pci converter. ( w7x86 )
all digital signals works fine with an external converter.
breakout unbalanced analog out and headphones are totally noised ( like playing some 24bits in 16bits converter )
there is also no reaction changing the output sensitivity ( Higain/+4/-10/XLRmode )
it's like the analog stage is not reached by the driver.
i'm using the lastest drivers and card firmware.
i checked the card on a native PCI/core2duo/W7x64 and it works fine.
i know it could be the pcie to pci converter, but in case of someone could have another issue such an i5 option or something like this.
thx
Re: HDSP9632 Analog outputs problem
No. It IS the converter.
3 (edited by SKL 2014-02-21 11:37:51)
ok....
thanks for your answer, anyway i'll use the card with external converters wink
i'll plan to use an AES EBU breakout, could it be affected in the same way ?
I believe MC might be referring t to the "pcie to pci converter"...
yes, is that i understood too,
i mean external converter as AD/DA trought adat, witch is working fine.
but AES/spdif is avaible in another sub-D breakout than analog.
in case of the pci-pcie converter make the analog stage out of function, is there a possibility that it put the AES/spdif stage out too ?
as adat is ok i think AES/spdif could be ok too...
The 9632 needs plus and minus 12 Volts for the analog section. I expect the converter to not provide that as it is not found in PCIe slots.
the adapter i use has a "floppy" molex plugged in to power the pci slot. there is another way to power the card correctly ?
8
Well, with the floppy connected it should work then. No other way.
9 (edited by SKL 2014-02-21 17:34:05)
unfortunately it's already connected big_smile
you might be right , the matter might be the minus 12V , the molex will provide a +5v and a +12v but no -12v. this is provided by the motherboard's main power connector.
the pcie1x host can provide only +12v, +3,3v , the molex might be here to provide more power to the 12v , and the +5v which is not present.
once again, it will work fine for my use, but if it can push the knowledge further ...;)
does anyone had already experienced something like that with a pcie to pci adapter ?
10
For Science, i soldered a wire from the main ATX to power the -12v pci pin, and it's works perfectly !
thanks you very much for the solution !
