Topic: Ipad Freeze with Babyface and the 219 firmware
Hi Mathias,
I wanted to use the last Totalmix FX 1.1 app with my Babyface and until i updated it with the last 219  firmware, my ipad 4 freeze in Class compliant mode. I must reboot my ipad everytime. The cable is official Apple camera connect cable and it works very well before the update.
The system is IOS 6.1.3.
I connected the Babyface with the last drivers for Windows 7 and all works well.
Thanks.
Djengo.
Re: Ipad Freeze with Babyface and the 219 firmware
So how do you power the Babyface?
With a 7800 mA Battery connected to the second usb of the Y cable.
Thanks.
Djengo.
That might be the problem. Try a real power supply for the BF, and maybe even using both.
Ok but why before, with a precedent firmware i didn't have problem ?
I must buy a power supply to test.
Thank you.
Former firmwares did not support Class Compliant mode, so how could it freeze the iPad then?
Hi Mathias,
I found the cause of the freezing Ipad ! It was the cable. I changed the cable with a new one and it works now. It's a pretty disturbing coincidence of having this problem same time as the firmware update...
In any case i am very happy with this possibility to pilote the Babyface with ipad. I waited for several month and i am not disappointed.
Thank you very much for your reactivity and your Professionnalism.
Djengo
