Topic: Unrecognised Multiface on my laptop: what solutions?
it seems that I came across this advice too late:
Note for HDSP PCI Rev. < 1.8 and the flat HDSP CardBus (15-pin connector)
!!! When the update fails (status: failure) the flash process should be repeated several times, until no error message occurs anymore. If the failure message is displayed nonetheless, the interface will most probably no longer work when the computer is switched off and on again. The interface then has to be re-programmed at the factory. We have invested a lot of work to prevent the system from getting in this state. If it happens despite our efforts, the best advice we can give is to not switch off the computer! As long as it is not switched off the old programming of the PCI/CardBus interface will stay active, and you can continue to work with the system using the old drivers !!!!
Now, my laptop says nothing when I plug my pcmcia cardbus, and I don't know what to do.
Do I have to send it to the garage, or is there anything I can do?
Thx.
