Topic: TotalMix Fx iPad app little request
Hello to the team,
As you may know, I particuly enjoy this iPad App in reheasal or in concert configuration.
Last night with my little band, we went for a private evening concert with just the Ufx and the iPad (only charged with 60% batteries) and the 5 m usb cable... It worked perfectly.
I switched off the screen when I don't use the iPad and it's perfect for the whole sets that started at 5pm and that ended at 10 pm !
There is just one thing that would help make it pefect :
For the 1.1 revision, you added the 2 rows view that I was exepecting, great !
But while in vertical position, with 2 rows settings, you still allow the finger screen vertical scrolling witch can be confusing when you think you move the slider up and down and instead you see the screen movements and not necessary in 2 rows view as there is nothing interesting above or under the 2 rows when they fit in this view.
Would it be possible to disable this vertical scrolling while in 2 rows view ?
Anyway, it's just perfect and once again congratulations on the good job !
Philippe
