1 (edited by Kaoutchou 2014-05-03 08:14:06)
Topic: Standby mode
My windows Seven box with Multiface doesn't enter in Standby mode anymore. There is an audio flux used on the RME that blocks it:
C:\Windows\system32>powercfg -requests
DISPLAY :
Aucune.
SYSTEM :
[DRIVER] RME Hammerfall DSP (PCI\VEN_10EE&DEV_3FC5&SUBSYS_00000000&REV_11\4&1b35
9d48&0&00F0)
Un flux audio est en cours d'utilisation.
AWAYMODE :
Aucune.
But I've killed every user application...
Could you help me please? It's driving me mad
Thank you
Driver date 4/1/2014 Version 3.4
Re: Standby mode
WDM in use?
Re: Standby mode
no use of RME WDM I guess. I use a generic audio card for system and regular applications and RME ASIO for audio apps.
I swept the standby problem under the carpet using the -REQUESTSOVERRIDE option of the powercfg utility but still, I have this audio flux in use without understanding where it comes from...
Re: Standby mode
Is there any onboard audio you could switch to? Does the Multiface still block standby then? Or does the onboard audio block standby then?
Re: Standby mode
I use an onboard audio card for windows audio but the rme does block standby. I don't get what's using it...
I disabled the RME in the Win Seven mixer with no change. It's the same when I disconnect the digiface using the settings.
Re: Standby mode
This is happening to me too, but not always, and not with any noticeable pattern.
C:\Users\Administrator>powercfg -requests
DISPLAY:
None.
SYSTEM:
[DRIVER] RME Hammerfall DSP (PCI\VEN_10EE&DEV_3FC5&SUBSYS_000010EE&REV_3C\4&342d
dffa&0&00E0)
An audio stream is currently in use.
AWAYMODE:
None.
Active processes (Win 7 64 bit):
http://s22.postimg.org/45ppndmpd/Processes.gif
7
Re: Standby mode
We have seen and also got reports a few times that Windows starts to hog WDM on start and doesn't stop to do so, means a continues playback although nothing has ever been started or used. But this phenomenon is not reproducable and not under our control as neither our drivers nor our tools start such a stream. Personally I use all (!) my computers with hybrid standby and never experienced one or the other.
Re: Standby mode
Thanks for the info Matthias... I guess these occasional mysteries are to be expected with Windows!
