Topic: Mac OS X 'configure speaker' to different MADI channels problem
Hi there,
I'm using the madiface USB with my Digico SD11/SD9 for recording/virtual soundchecks, and music playback in between shows.
I'm running firmware v20, driver version V1.94.
I'm using the madiface both with 48Khz and 96Khz sample rates.
I'm running the software on a macbook pro retina with SSD and 16gb ram, OS X 10.9.2.
I'm using cubase 7.0 for music recording and virtual soundcheck, which works fine. The routing to different MADI channels works fine.
I'm using Smaart V7.4.3.2 for analysing audio stream running to my monitors and FOH to identify feedback frequenties. I route madi channels 21-24 from the digico desk to Smaart, works fine also.
But when i'm trying to play music in between shows with spotify or other programs, the audio is always being routed to madi output 1 and 2.
Whatever channel I choose in the audio/midi configuration in mac os x 'configure speakers', music is alway coming from channel 1 and 2.
At first it was only spotify that didn't follow the configured channels, quicktime player seemed to play via the correct madi outputs 27 and 28, but now all my music programs that follow the audio output configuration from mac OS X seems to want to go to channel 1 and 2.
I allready re-installed, reflashed the madiface USB with the latest software, but the behaviour stays the same.
I'd really hate to reroute all my other default cubase sessions to start with channel 3 because of the need of music playback in between shows.
What is causing this? I did a gig last week with the previous firmware/driver, which worked just fine with the routing, but since I updated the drivers yesterday I see this kind of behaviour. Also my macbook froze a couple of times.
With my Digico UB Madi I don't have these issues. Unfortunatly that device is only capable of 48Khz sample rate, and 96Khz gives me very low latency (1ms roundtrip).
Anyone any suggestions? Thanks in advance!
Greetz!
