Topic: Burl Mothership and RME
hello,
what i saw here is burl mothership can only connected via HDSPe MADI. i was also needed Adat1 (input) from a laptop and Adat2 from a another pc (to record all synths etc)
so does RME has similar soundcard that has MADI i/o for Burl Mothership and 2 pair of ADAT i/o?
regards
Re: Burl Mothership and RME
Sorry, no. But you could put an ADI-648 in between, and use this to merge the ADAT channels into the MADI stream.
Could be cheaper to add a suitable ADAT card from the HDSP(e) series, they should use the same driver so you can use them simultaneously. Right?
Yes, with the exception of the MADI FX and Madiface XT. But HDSPe MADI and e.g. Raydat share an ASIO driver.
