Topic: Totamix control room section
Hello RME
Have you considered making a control room section in the Totalmix, or in a seperate window, with a control room knob/fader linked to the monitor main you’ve chosen? Maybe you can dedicate outputs to like three different monitors and have a monitor selector to? In this section you would also find the mono and talkback-switch. In an expanded view you will also find the phones levels (linked to the outputs you’ve chosen). If you can then choose to hide the rest of Totalmix (or have it in a seperate window) this will be a pretty small window that can easaly be placed on top of everything else without problems. Ultimately you will make a hardware midi/usb-control box to this section with a BIG-knob, monitor selectors and a talkback switch which also could be controlled by a foot pedal. What do you think?
Bjørn Ivar Tysse
