Topic: Compatibility old AI4S-192 for 9632 with HDSPe AIO ?
Is the old expansion card AI4S-192 compatible with the HDSPe AIO ? Thanks.
Re: Compatibility old AI4S-192 for 9632 with HDSPe AIO ?
Some expansions will need a small modification. You can mail me the AI4S' serial number to be sure.
3 (edited by mistaklawd 2011-02-16 08:37:29)
I hope the serial number is the one with bar code : 22342587. Thanks
Sorry : I sent you an e-mail
No, it is not. None of them.
http://www.rme-audio.de/en_products_hds … boards.php
5 (edited by mistaklawd 2011-02-16 08:47:24)
First link is wrong and second does not give me any solution.
Sorry : I did not saw the first part of your answer : then it's wrong... bad new...
Please contact your retailer or the french distributor (SCV), if you purchased the card in France. The card can be modified.
The retailer of the HDSPe AIO or the AI4S-192 ?
That page clearly states:
Note: AI4S-192 and AO4S-192 (without the suffix AIO) do work only with the HDSP 9632. The current Expansion Boards with the suffix AIO work with both cards.
The one of the AI4S - this is the one that needs the mod.
10 (edited by mistaklawd 2011-02-16 09:04:56)
Thanks. I had to read more seriuosly that page... before changing my 9632 for HDSPe AIO... You should write this with bold police !!
Why do I have 2 answers different between Mathias and Daniel ? Is there something to do or not ?
11 (edited by Kingston1 2019-03-07 20:08:04)
I also would like my AI4S-192 and AO4S-192 expansions to work with the HDSPe AIO card. I have been trying to solve this issue through email without success.
Mr. Daniel Fuchs from RME support informed:
the cards require a small modification to work with the AIO.
Please contact
Studiotec Oy (finnish distributor)
I have been in touch with Studiotec who are clueless to the possibility of such mods. They further verified from Audio AG's Michael Hoepp - another link in this Kafkaesque chain - that "this mod is not financially sensible because it would be so expensive compared to buying new expansions instead".
I have initially even offered to do this modification myself - being experienced electrical engineer with SMD experience and tooling. But info on the modification is not available apparently.
Other than being inspired to read more Kafka, what exactly am I supposed to do now?
