Topic: hdsp 9632 -not able to use latency under 512 for vsti
Hi!
Suddenly I'm not able to use my Hdsp 9632 under 512 samples when monitoring vsti's.
512 is fine, under gives more and more distortion.
I haven't really checked if audio-monitoring is affected the same way.
Drivers should be newest.
DAW is Reaper
OS: XP sp3
Thanks for all help!
www.g-sun.no/en/
Re: hdsp 9632 -not able to use latency under 512 for vsti
i have problems with 1024 samples, playback with 512 is'nt possible in great Arrangements, my drivers are the newest from August 2010
Seems like playback is affected the same way. I can play a loop with 256, under that, it's just distortion.
Before I had no problem running 64 samples.
www.g-sun.no/en/
Same in Sonar 8
www.g-sun.no/en/
Reflashed the card, and everything back to normal smile
Seems however that there are some strange things going on her, since I had driver-problems a couple of weeks ago:
http://www.rme-audio.de/forum/viewtopic.php?id=10343
Any ideas?
www.g-sun.no/en/
Did you do a complete shutdown/cold boot, when these issues happen? If not try that. If you did, try memtest to see if your system is ok
7 (edited by G-Sun 2011-03-04 13:36:49)
No shutdown/cold boot when issue appeared. But, did cold boot after reflashing card, so could be that roll
Yes, I'll run a memtest. Thanks!
BTW: Does the firmware load into RAM?
www.g-sun.no/en/
8 (edited by vinark 2011-03-04 15:22:09)
No onto the card. But indeed could have been just the cold boot that fixed it. I have had that sometimes too, when the lower buffer settings would corrupt (by me by overloading the cpu) and only a reboot would fix it.
maby we should go over your system
make and model of whats inside will help..
10 (edited by G-Sun 2011-03-04 23:09:35)
Thanks smile
My gearlist is:
    * Mainboard : AOpen AX4PER-GN
    * Chipset : Intel i845PE
    * Processor : Intel Pentium 4 @ 3066 MHz
    * Physical Memory : 1024 MB (1 x 1024 DDR-SDRAM )
    * Video Card : RADEON 7000 / RADEON VE Family (Microsoft Corporation)
    * Hard Disk : SAMSUNG (250 GB)
    * Hard Disk : WDC (160 GB)
    * DVD-Rom Drive : TSSTcorp CDDVDW SH-S222A
    * Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3
    * DirectX : Version 9.0c (mars 2006)
www.g-sun.no/en/
G-sun: what bios rev is the board running and where did you get the chipset/inf
drivers for xp32 for your chipset..
Thanks!
OEM Signature :    AX4PER-GN R1.05 Jun.23.2004 AOpen Inc.  (Newest)
BIOS Version/Date    Phoenix/Award Technologies, LTD 6.00 PG, 23.06.2004
SMBIOS Version    2.3
The chipset-drivers are updated from AOpen.
But I'm not sure everything is fully updated, cause I found it a little difficult.
www.g-sun.no/en/
13 (edited by v24s 2011-03-05 20:12:18)
hello...   AX4PER-GN
BIOS         R2.04     1/27/2005  is the last bios, i did not see updated chipset drivers at aopen for the os, im going to look at intel again, might the issue be your
processor power. Im running X-1a with no errors and it takes a well setup system
with all the processor power you can toss at it, il look back later
this inf is too old
AX4PER-GN
Driver     Intel Chipset Software Installation Driver     R5.00.1012 PV     4/9/2003
2464.0 KB
#     Intel Chipset Software Installation Utility for Windows 98SE/ME/2000/XP
OS Support:Win2000,Win95,Win98,Win98SE,WinME,WinXP
http://www.intel.com/support/chipsets/sb/cs-009236.htm
Intel® Chipset Software Installation Utility ONLY for 845pe, your board
Intel® 845PE Chipset     **     Download, just this driver
Thanks a lot smile
The Bios is latest. I have:
Product :    AX4PER-GN
Version :    918AF10401
and the R1.05 is latest for that version.
I'll check up and update the others as you suggested smile
www.g-sun.no/en/
Checked
A little unsure about what to download and install, so used the Intel Driver Update Utility:
http://www.intel.com/support/detect.htm
and it reported:
Intel Chipset Software Installation Utility (Chipset INF)
Product Detected     Intel® 800 Series Chipsets
Current Version Installed     5.00.1012
This version is valid.
I updated just the network-driver, as it was the only thing suggested by the utility.
www.g-sun.no/en/
Searched for 845PE in the Download Center
but didn't find any thing.
A little unsure about what to do..
www.g-sun.no/en/
Latest Intel Chipset Software Installation Utility is version 9.2.0.1021.
Downloaded:
File name:
INF_allOS_9.2.0.1021_PV.exe
Version:
9.2.0.1021
In the extraction-part I got the message:
"Your PC does not meet the minimum requirements for installing the software. Setup will exit."
www.g-sun.no/en/
Dandruff: thanks for the input !! g-sun i was hoping to get you system updated and performing the best it could be............... its going to be hard as intel is not supporting
many of their chipsets and yours is  tough build, many issues with that chipset.
in the futrue if other members would conside this motherboard to build on..
http://www.supermicro.com/products/moth … /C7P67.cfm
you have to wait intel sata issues, but will soon be out.. killer motheboard
G-Sun wrote:
Downloaded:
File name:
Version:
9.2.0.1021
Weird. Should install fine on
  Microsoft Windows Server 2003
    Microsoft Windows Server 2003 x64 Edition
    Microsoft Windows Server 2008
    Microsoft Windows Server 2008 x64
    Microsoft Windows XP Professional x64
    Microsoft Windows 2000
    Microsoft Windows Vista
    Microsoft Windows Vista x64
    Microsoft Windows 7
    Microsoft Windows 7 x64
    Microsoft Windows 2008 R2
    Microsoft Windows 2008 R2 x64
Well, I wasn't confident it was for my board..
www.g-sun.no/en/
Had the same issue again, fixed with hot boot
www.g-sun.no/en/
