Topic: No output to headphones - UFX / Mac / Logic 9
Hi all
I have tried adjusting all settings I can think of to set output via the phones 1 (9/10) output on the UFX, to playback what I managed to record (after similar difficulty adjusting the input signal path ... I have to say, the UFX manual seems deficient to me when it comes to instructing on setting inputs/outputs, especially for a relative novice like myself) ...
After several hours, I still can't play back what I have recorded in Logic 9 via my headphones plugged into Phones 9/10 output on the front of the UFX ... ... what am i doing wrong?! HeadScratch Or could it be a hardware issue (unit seems fine though ... MUCH more likely a software setting issue ...)
Anyone else had a similar problem to this ... ?  Hopefully I have just failed to do/set something simple ... fryingpan
Please help?!  ed:
Thank you
Kind regards
Kieren
PS - I am using an older set of Toshiba HR-50X 8 Ohm earphones, which work fine (as I used to use them with my Boss BR-1600 ...)
Re: No output to headphones - UFX / Mac / Logic 9
First make sure you are in Submix mode.
Next select the output 9-10 so that it is highlighted( phones 1).
Now look at the middle row and bring fader 1-2 up to 0.
Voila!
/Eric
RME Fireface UFX
Mac Mini 2.6 GHz 16 GB Ram Areca RAID | MacBook Pro 2,2 GHz 16 GB Ram | OS 10.10.5
Hi Eric
Voila indeed!  :-)
Many thanks for your help!  cool
K
kman79 wrote:
Hi Eric
Voila indeed!  :-)
K
You're so welcome! :-)
RME Fireface UFX
