Topic: No output to headphones - UFX / Mac / Logic 9
Hi all
I have tried adjusting all settings I can think of to set output via the phones 1 (9/10) output on the UFX, to playback what I managed to record (after similar difficulty adjusting the input signal path ... I have to say, the UFX manual seems deficient to me when it comes to instructing on setting inputs/outputs, especially for a relative novice like myself) ...
After several hours, I still can't play back what I have recorded in Logic 9 via my headphones plugged into Phones 9/10 output on the front of the UFX ... ... what am i doing wrong?! HeadScratch Or could it be a hardware issue (unit seems fine though ... MUCH more likely a software setting issue ...)
Anyone else had a similar problem to this ... ? Hopefully I have just failed to do/set something simple ... fryingpan
Please help?! ed:
Thank you
Kind regards
Kieren
PS - I am using an older set of Toshiba HR-50X 8 Ohm earphones, which work fine (as I used to use them with my Boss BR-1600 ...)
