Topic: Problem installing the firmware update on Windows 7 64
I use Fireface 400 (firewire).I've just installed windows 7 64-bit Ultimum.I downloaded the latest drivers,that would be win_fire_3034.zip.I even tryed the new update 3044.My firmware version is 1.70 and it doesn't work well with the new drivers.I tried to install the Flash Update Tool that updates the firmware to 3.36 version but nothing happens.I try to open the exe file (which in windows 7 is recognised as application) but nothing happens.No response.I tried to boot from a flash disk to try and install it as recommended in the site but nothing happens.So right now with the new drivers (3034,3044) and the 1.70 firmware versions I keep getting errors in the fireface settings panel and it can't play correctlly.any ideas?
