Topic: Totalmix high CPU use under XP3
I'm experiencing high 40-50% CPU use (core2duo 2ghz) totalmix.exe in the task manager when the totalmix window is open. The cpu usage is less when the totalmix window is closed but i thinks is still high.. sometimes it jumps to 16-18%.
Can i close the totalmix.exe in the task manager after setting my routing preset?
I know i will not able to use the eq /dsp things but the system will be stable?
