Topic: ff800 problem analog out 1 with 4db in less
My poblem FF800 has an analog output 1, if I send a test signal to the outputs 1 and 2 exit 1 has 4 db less.
I did all the tests on the cables and the signals are equal but TotalMix analog output channel 1 there are 4 db difference.
I think it's a hardware problem, what can you do?
There is out of calibration?
best regards
Peppe
