Topic: Is the BabyFace right for me?
Hi all, need some help working out whether the BabyFace is the right audio interface for me.
After reading the documentation I have the following queries:
1. Driver stability. I have an iMac that is used both as a very small studio AND living room computer, which is used by more than one person under different OS X accounts, and regularly put to sleep when not in use. I've had a lot of issues with various other audio interfaces in the past, both USB and Firewire, where they get into some weird states typically where no sound comes out after waking the computer from sleep, often requiring a reboot (I suspect driver stability issues).
I really hate it when I come home from work and my wife says "I couldn't get any sound today" (she only uses the audio interface for iTunes). If there's one thing I want from an audio interface, it is that when you press Play in iTunes, SOUND COMES OUT. I heard that RME have very stable drivers, so my question is - do they keep working reliably even after successive sleep/wake cycles and different users logging in to the computer?
2. Lack of modal behaviour affecting main outputs. I want an audio interface with a minimum of modal behaviour affecting the main outputs, so you can't easily put the device into a strange mode where no sound comes out of the main outputs by accident. The only real modal behaviour I can see on the BabyFace is that the Select and Dim functions for the main rotary controller, which I think I can live with. But I'm not sure about what modal mayhem you can create with TotalMix and whether this survives sleep/wake and logging in as a different user. (It might be OK because whatever I do in TotalMix, I'll probably always have the main system output routed to outputs 1 and 2 anyway.)
3. What setting does the rotary's Select button default to, when you first switch on the Babyface - Out? And if you put your computer to sleep and wake it up again, does the Select button return to the default setting, or does it remember where you left it?
4. If you select the BabyFace as your OS X system audio output in System Preferences -> Sound, is the overall OS X system volume control in the top right menu bar still usable, or is it disabled?
5. Can I route a stereo pair to an external effect unit and back for processing, while still monitoring on the main outputs? It sounds like I'd need to use the additional headphone output (unbalanced) 3+4 for the send, and the input XLRs for the effect returns, correct? That means the send is unbalanced and the return is balanced, which seems a bit strange.
6. Regarding headphone volume - I have a pair of AKG K240DF phones which are 600 ohms, I understand they will be quieter because this is a very high impedance. But just how quiet? I like to monitor at fairly low volumes anyway. I also have a pair of Sony MDR7509 phones which are 24 ohms I believe, but I prefer the AKGs because they're semi-open and clearer sounding.
Thanks!
