Topic: ADM pans channel to right
Using Asio Direct Monitoring in Cubase 5:
one mono input bus (source AN1)
TotalMixFX setting for AN 1/2: not stereo, each mono channel panned to center.
When Monitor is activated from DAW's track everything's ok (input is routed to both channels of the stereo output);
when deactivating Monitor, routing dissapears (volume drops to 0) but the panning for Input AN1 gets stuck totally right (R100).
I have no other DAW to test if this is a Cubase issue or a flaw in TotalMixFX.
