Topic: ADM pans channel to right
Using Asio Direct Monitoring in Cubase 5:
one mono input bus (source AN1)
TotalMixFX setting for AN 1/2: not stereo, each mono channel panned to center.
When Monitor is activated from DAW's track everything's ok (input is routed to both channels of the stereo output);
when deactivating Monitor, routing dissapears (volume drops to 0) but the panning for Input AN1 gets stuck totally right (R100).
I have no other DAW to test if this is a Cubase issue or a flaw in TotalMixFX.
Re: ADM pans channel to right
Cubase issue. It definitely sends what you see in TM FX. Apart from that its not a big problem. Whenever you engage the monitoring it (Cubase) will set the pan correctly again.
Thank you Matthias!
