Topic: Multi-Client Setup
I have the HDSPe AIO card which I am using the Analog 1/2 outputs in my DAW with ASIO for playback.
I am trying to simultaneously send this audio output from my DAW also into the Flash Media Encoder but I get no signal.
Does anyone know basically how I could simultaneously send this playback output from the DAW into another program such as the Flash Media encoder? I am using Windows 7 64bit.
I am trying to broadcast a live Webcam music show.
Thank you for any advice.
Re: Multi-Client Setup
Loopback. Explained more in the manual. You press Ctrl and left mouse button on a selected output. I suggest you use another output rather than your main outs, then you can easily adjust the level. Then in your other program select the input you looped back.
Isaac P
Or use the latest driver it has multi-client ability. I would tend towards loopback though as it gives you more versatility to change your listening and sent levels independently.
Isaac P
Thank you very much for the info, I've now enabled Loopback on 2 seperate channels from my main outs as you suggested and it works fine.
