Topic: Routing with hdspmixer
I reactivated my hdsp 9632 in Linux today and try to get a custom routing pattern in hdspmixer.
If I select a output channel in the drop down menus nothing happens. If I open the dropdown again the previously selected channel is deselected again.
Is there still a way to set routing manually like it worked a few years ago with
"amixer -c 1 cset numid=5 src,dest,gain"
Specificly I want to route several Playback Channels to SPDIF if needed.
SPDIF out works only if I select Preset 6 and therefore route all Channels to SPDIF which is not my desired goal.
I am using in-kernel alsa (kernel 2.6.39.1)
alsa-tools-git
alsa-utils-1.0.24.2
hdsp 9632 firmware v154
gentoo linux
