1 (edited by punkrockdude 2014-02-12 14:44:30)
Topic: HDSPe Multiface II + Ubuntu 11.04 x64. Problems.
When I type hdsploader in the terminal I get the following:
hdsploader - firmware loader for RME Hammerfall DSP cards
Looking for HDSP + Multiface or Digiface cards :
Card 0 : HDA Intel at 0xfdcf8000 irq 22
Card 1 : RME Hammerfall DSP + Multiface at 0xfdff0000, irq 18
Upload firmware for card hw:1
Unable to open file '/lib/firmware/hdsploader/multiface_firmware_rev11.bin' for reading
Card 2 : HDA ATI HDMI at 0xfebfc000 irq 46
a2000@ubuntu:~/Downloads/alsa-tools-1.0.24.1.43.gcb407/hdsploader$ hdsploader
I have looked but can not find multiface_firmware_rev11.bin in /lib/firmware/hdsploader/. There is not even a folder in firmware that is called hdsploader. I have installed alsa-tools-gui and alsa-firmware-loaders but all I can see in Ubuntu's sound properties are the ATI and Intel sound cards. In programs I can open HDSPConf but not HDSPMixer.
What can be the problem? Regards.
Re: HDSPe Multiface II + Ubuntu 11.04 x64. Problems.
You must build the firmwares manually. You can get the firmware sources here.
Extract it to a folder and type ./configure>make>make install. After that mkdir /lib/firmware/hdsploader and copy the  multiface_firmware_rev11.bin to /lib/firmware/hdsploader/.
Thats it.
After loading the firmware you must start one time the hdspmixer to unmute the channels.
A small script like this can do that:
#!/bin/sh
hdspmixer & sleep 3 && killall hdspmixer
Greets
Thank you so much for the help, frog993. I managed to configure, make and then with sudo create hdsploader dir and copy the bin file to its correct place. One thing I don't know is how to exactly setup that script you mention in the end. Can you write a little quick guide, please? Regards.
This is really wierd. I only get the sound card to work if I turn off the power to the external Multiface II so that it lit red. then I start hdspmixer and after that hdsploader. that way it sometimes works and the hdsploader works successfully. It works really badly. I am on Lubuntu x86 now btw.
I also don't know how to create the following script:
#!/bin/sh
Regards.
6 (edited by punkrockdude 2014-02-12 14:43:38)
If I type hdspmixer I get:
    a2000@a2000:~$ hdspmixer
    HDSPMixer 1.6 - Copyright (C) 2003 Thomas Charbonnel <thomas@undata.org>
    This program comes with ABSOLUTELY NO WARRANTY
    HDSPMixer is free software, see the file COPYING for details
    Looking for RME cards :
    Card 0 : RME Hammerfall DSP + Multiface at 0xfdff0000, irq 18
    Multiface found !
    1 RME cards card found.
    Initializing default presets
    Segmentation fault
If I try hdsploader instead I get:
    a2000@a2000:~$ hdsploader
    Upload firmware for card hw:0
    Hwdep ioctl error on card hw:0 : Device or resource busy.
During these things, if I have a player like Audacious playing a song and I will hear sound
for a quarter of a second if I execute hdspmixer during playback and then the sound goes away as
hdspmixer itself disappears right away.
Now to the "solution" but it is not a solution I accept..........
1. unplug the multiface ii external box power and start hdspmixer.
    Multiface found !
    Card 1 : HDA ATI HDMI at 0xfebfc000 irq 47
    HwDep ioctl failed. Metering stopped
Now the mixer shows up and doesn't disappear.
2. turn on the power to the multiface ii external box.
3. start hdsploader in a new terminal while hdspmixer is still open in the first terminal.
    Firmware uploaded for card hw:0
4. Touch the faders on Out 1 and Out 2 in the hdspmixer and put them back at 0dBFS.
IT WORKS! I don't know why I need to have my external box turned off when I start
hdspmixer or the mixer will vanish immediatelly.
7 (edited by punkrockdude 2014-02-12 14:45:10)
I noticed that if I logout and login again without any reboot I have to power it off again like "normal", start hdspmixer but this time hdspconf to make it work. if i start hdsploader instead of hdspconf i get the
I hope these findings can help me and others. I am using latest Lubuntu but with a lowlatency kernel. I also had to find a alsa-tools deb package on a website to have access to hdspmixer.
As soon as I close the terminals or the hdspmixer window the sound goes away.
Regards.
Anyone know what might be going on and why this happens? I would love to fix this because Linux is really interesting to me and I would like to be able to evaluate it properly. Regards.
