Topic: Help Syncing 2 Multiface IIs - OS X
I have 2 multiface 2's , recent firmware updates etc, connected to my mac pro via pcie.
I have set the 2 up as an aggregate audio device, with one as the master clock, connected to the 2nd unit via optical for sync.
I have a couple of newbie questions.
1.) Do i need 2 optical cables, so out from the master to input of the slave, then from slave out to master in? (currently only using one cable)
2.) When using outboard processing on the slave I often get audio glitching (not buffer size related) which i can only cure by clicking the "resample" checkbox on the aggregate audio device. After a while the noise comes back. Any idea what's going on there? SHould resample be selected, even if one of the units is set to master and the other to slave?
any help appreciated
thanks
