Topic: connecting RME Fireface 800 and Dolby DP564
hello,
I'm wondering if there is a way to hook up those 2 devices, so that I wouldn't have to switch output cables all the time...
basically the DP564 has:
1) BNC digital inputs (AES3-ID compliant)... that supposedly can receive both DD and PCM signals
2) Optical in (no information on that one...)
3) Ethernet in (that works with DD server app)
Now i've tried to connect it through ADAT 1 OUT (FF800) to OPTICAL IN (dp564) but DP564 shows "no input" info on the screen... so no go...
I'm quite new in the surround mixing field (especially connections of gear) so your help would be very appreciated !!!!
Cheers
Chris
