Topic: latency problem with live on mac.
hi there,
I have a multiface 1, a mac pro 10 5 8. I just bought the hdspe pci card so I can have the multiface on the mac, it seems to work, as the mac recognise the card. I install the hdspe 277.pkg for the driver
BUT
in ableton live 8. in the preference audio,
in the first box (type de pilote) I can choose between coreaudio or no audio, isn't that strange? shouldn't it be a hdsp or hammerfallsomething to pick up?
then in the two next box (peripherique d'entrée audio et periphérique de sortie audio) i can choose hammerfall dsp multiface (slot2)
I have to put the latency in the soft to 92 samples and it's the limit for live not to crackle the sound
and i get an input latency of 3,35ms and ouput latency of 4,06ms and a general latency of 7,42 ms
I get nearly the same result even better with the internal soundcard of the mac.
I thought I should get a zero latency.
is everything normal?
the driver in sytem/library/extension/ is hdspmadi.kext
thank you:)
