Topic: Protools 9 native and AES32 no sound at 1024 latency.
I'm running Protools 9 with the RME AES32 card hooked to a LYNX Aurora 16. My system is an intel i7 930 with 6 gigs of ram. Windows 7 64 bit. System runs great under Cubase 5.
Protools 9 runs fine at 512 and under latency but will not playback at any buffer larger than 512. Protools also is not as efficient running a lot of vst plugins as is Cubase or Nuendo. I'm also running the fxexpansion vst to rtas wrapper which they claim has little to no load on the system.
Is anyone else experiencing this problem? Really need a solution to this problem because Protools chokes after setting up plugs for a mix.
