1
Topic: How I can to make multi channel wav for playback in the RME FF UFX?
Please help!  I want to use UFX in the live without computer. But don't understand how I can to make multi channel wav in Logic pro (for playback in the RME FF UFX)?
Re: How I can to make multi channel wav for playback in the RME FF UFX?
I think Logic don't support standard multichannel wav files. But you can play them in Logic to different playback devices and record them as new file in the UFX.
best regards
Knut
3
Thanks! What soft can do it (mix to multi-channel file)? And can I to select split files (from mix multi-channel) in different out in the RME FF UFX?
Pro Tools and Reaper.
I 'am not sure I understand. You can select one multichannel file for playback. Every channel can be assigned to an output channel. Channel 1 to channel 10, 2 to 8 ...
best regards
Knut
5
Thank you Knut! I understand all.
I export 5.1 mixes to multichannel wave files from Sonar... so there's another one for the list.
