Topic: using the RME HDSP 9632 to do multitrack recording
Hi
I need some advice about how best to use the RME HDSP 9632 card in my PC to record a live band.
I want to record direct into Cubase 6 on the same Windows Vista 64bit PC.
I want to get up to 14 tracks recorded live and simultaneously into Cubase 6.
I have an Allan and Heath CP20 powered mixer but it doesn't have firewire or USB outputs, just the 20 channels with standard jack outputs per channel.
I assume I will need an interface of some kind to take outputs from the mixer and feed them into the sound card and then into Cubase?
Realistically, I will probably only be using 6 - 10 outputs simulatenously, but it would be good to have the option of up to 14 or so.
Any suggestions how I do that?
Barry
