Topic: UFX/Total Mix Freeze under Snow Leopard
I'm preparing a live with a band, controlling Total Mix with NI Maschine (through Mackie Protocol) on the MIDI port 2 of the UFX. The sound is great and the unit is amazing, Durec too...
I use an april 2010 macbook pro/firewire, have updated the firmware and the driver to the latest version.
12 analog inputs, 6 analog outputs, AES and ADAT 1 to 10 are used to rec with Durec
1. Sometimes, when I boot the mbp and then the ufx, the screen of the unit freeze and Total Mix doesn't support "MIDI" control, the sound pass through for sure but no more way to access the different submixes.
2. In the Preferences, I've set Maschine as MIDI input and output, and it works generally smoothly, but everytime during a rehearsal the controller or ??? freeze : no more way to adjust volumes, pans, choose a submix... the only way to get again the "hand" on Total Mix through the controller is to reboot the mbp and the ufx, which make me freeze when I think to next saturday show :-O
I may have do something wrong, thank you in advance for your advices
Ben
