Topic: Ableton with TotalMix and using a midi controller
Hi all!
I am wondering if anyone has any tips on how to link audio / midi tracks from ableton to TotalMix for ease of mixing and keeping everything neat and in one place. At the moment I can control the master volume in the second softare row in TotalMix, is there a way to route individual tracks from ableton to TotalMix? Is this even the best way to go about mixing in this instance?
Also at the moment I leave my physical output channel set to maximum and control the level coming out of ableton to my monitors via the software fader in row 2 in TotalMix, is that best way to go about it? I should also mention that I am running an MR816X into the 9652 via Adat and using that as my monitor output.
And finally, what is a good midi controller for use with TotalMix? I have seen the Behringer bcf2000 used quite well for this, it is the best option or is there a better unit available?
So I guess my main aim here is to have all my individual tracks in ableton routed to TotalMix and then use a midi controller with TotalMix so I can mix more hands on and not have to reach for the mouse constantly. I am mostly recording guitar, bass and vocals through the MR816X into ableton then adding some soft synths and virtual drums, so again if there is a better way to go about this than what I have put forward please let me know, I am only new to the 9652 / MR816X / midi controller combo
Thanks very much
Junks
