Topic: Adjusting Analog Inputs 1 and/or 2 makes Main Output reduce volume
When I use the rotary encoder to adjust the input gain of AN1/2 (either as a stereo gang or individually) the Main Control Room output (assigned to AN1/2) reduces by 8dB or by 4dB. It happens after I've pressed Recall, which I've setup to take the Main Output to 0.0dB. It doesn't matter if I increase or decrease the gain, the Main Output drops by 8dB or 4dB. If I alter the gain with the mouse on the TotalMix gain wheel, the problem doesn't arise. At first I thought it was a feature, but the fact that it is a variable drop, and only happens when I use the rotary encoder makes me think it might be a bug.
Dominic
New Babyface. Firmware v184, Driver 1.62 TotalMix0.962 Mac OS 10.7.2, MacBook Air (2011)
