Topic: FF800 noise/click/pop when switch programs
I am pasting what I've just emailed to support, maybe someone from the forum had the same experience and hopefully a solution:
Operation system (version/service pack): Win 7, SP1 64 bit
Mainboard Gigabyte Z68x UD5
RAM amount 16 gb
Network adapters : realtek PCIe GBE
Graphic card : Sapphire HD 5570 1gb DDR3
Other installed soundcards : none, built in is disabled
Which audio software (version) shows the problem: I think it happens when I switch between software that uses the audio card driver, and I guess it has to do with change in sample rate, because it mostly happens when, say, I switch from cubase project (44100 hz project) to google chrome with youtube opened (guessing a 48000 hz video?)
I have been using my FF 800 for 3 years with XP, and it was rock solid, I could switch between software and the programs handled the sharing of the driver pretty well..However I've upgraded my machine to a win 7 64 bit and this is my 4th day with the new machine, all my drivers are up to date and my problem is this: When I switch between software FF800 makes either a loud click noise (something like clock error noise) and sometimes a very loud whitenoise-like burst of noise....This is random of course, not always it happens...I am using FF out 9-10 as my windows audio out, and the rest as my cubase outs...But for some projects in cubase maybe 9-10 could be active too....could that be the problem? Or is there a known noise/pop/click problem with ff 800 - win 7 64 bit combo?
Cheers,
Emre Yazgin
www.emreyazgin.com
Thanks a lot in advance!!
Re: FF800 noise/click/pop when switch programs
Driver version and firmware version?
MAtthias, thank you so much for your reply and interest but it has stopped doing it since I've disabled all the inputs and outputs that I am not using from the windows's audio devices section. Thanks again.
