Topic: Problem on the line/instrument (3-4) inputs on a fireface400
since I upgraded the firmware to the last version (on mac osx lion) , when i use the ff400 inputs (3-4) after two or three hours the FF400 start to make some clicks and clip like if it was a sample rate error....mmhmh strange what can i do??????? on  osx lion first time on october i had to install the usb driver to let the FF400 works but from the last update it gives me this big mistake...heeelpp pls!!!
Re: Problem on the line/instrument (3-4) inputs on a fireface400
Which USB driver did you install? There is no way the FF400 will work with a USB driver...
Does the settings dialog show "Errors"?
the ufx drivers as you suggest the name of the driver is fireface USB and i had to install it when the driver for lion where not ready, anyway the settings dialog don't show any error, but if i change the input 3-4 with the input 5-6 or 7-8 it works good but I need to use the front-input..i need the pad! so what kind of problem is it? it comes only when I upgraded the driver on the end of november...
There is no way a USB Fireface driver will work with the F400... HeadScratch
Can you record these clicks?
on october i read on that forum that the only drivers that were working on lion osx were the ufx driver and with 'em i had no problem of rating! but when I changed them into the original fireface driver now compatible with lion it started to do that...I did'nt try to record these clicks but they appear too when I open my daw (ableton) or some player like Itunes, just on the first time opening of the program...
so where can I control the version of my firmware?
