Topic: Tele to XLR input on Babyface?
I am going to connect my Roland JV-2080 to my Babyface. It's an old synth, so it only has left and right tele 1/4" out. I want to connect them directly to the 2 x XLR inputs on my Babyface. According to the manual that should work fine, it also has some cryptical info about connecting the "ring" of a stereo TRS jack, and pin 3 of a XLR to ground.
I red this somewhere else: "You need to make sure that pin 3 and pin 1 are shorted together (-ve to ground), and that goes to ground on the other end of the cable. pin 2 of the XLR (+ve) goes to the tip of the phono or jack plug."
Can someone tell me what cable or adapter I should get? Will this one do the trick:
http://shop.klotz-ais.com/cgi-bin/quick … g&ls=e
How do I know if it is wired correctly?
I do not know all this technical stuff. Don't tell me I need a DI-box.
David
