Topic: Different sample rates on same PC possible?
I'm a mastering engineer, and at the moment I have an HDSPe AES, which I use for transfer and capture to and from an analogue outboard chain (via separate Crookwood D/A and A/D converters).
It appears that you can only have one sample rate per PCIe card, is that correct?
I'd like to be able to transfer at one sample rate, e.g. a 96kHz source file, and capture at another, e.g. 44.1kHz, as this would bypass the degradation caused by having to use a sample rate converter after the fact.
I know Samplitude Pro X (my main DAW), allows different audio tracks to have different sample rates, so I am wondering if this would be possible on a single PC, if I bought another RME PCIe card?
Thanks in advance,
Gregg
