1 (edited by Michael A 2012-03-06 17:18:59)
Topic: The Mute Button
is there anyway that when i mute a mic in a certain mix, it mutes it only for that particular mix, and not for all mixes? solo works fine for individual mixes but mute seems to affect all the routings of the input. (fireface ufx)
FF UFX - ARC - U87Ai - 828Mk3 Hybrid - Digimax FS - Tascam MH8 - MIDI Express 128, 24GB RAM, i7-3630
Re: The Mute Button
Use a mute group.
Re: The Mute Button
using mute groups i'm still limited to 4 groups, and i'm using 10 stereo mixes at the same time. its also not very convenient when setting up the performers' mixes, is there any technical aspect that prevent adding an option to use mute individually for mixes?
Re: The Mute Button
Our whole internal design, sorry. You might be able to work around this limitation with some tricks like Solo or using the Mic channel's fader itself with Undo...
Re: The Mute Button
ok thanks.
