Topic: Fireface400 driver 3.06 causing audio dropouts in Ableton Live
Hey all, just a heads up on an issue I've been having with the latest firewire driver version 3.06 on my 2.66gHz i7 MBP running OSX 10.7.3.
After installing the update, I started getting really bad audio dropouts and digital spikes when I tried to do anything in Ableton Live 8 (all versions, including the newest betas). Using the same driver, there are no issues in Logic Pro 9, or the latest version of Studio One 2. Downgrading to the version 2.90 firewire driver solves the issue, playback is normal in Live with no issues.
100% reproducible if I try installing the 3.06 driver again. 2.90 is fine for me so I'll continue to use it, bu wanted to bring the issue to the dev's attention.
http://tarekith.com
