Topic: Assign Mains to mono output for FOH work?
I am working on setting up Total Mix with my UFX to use for mixing FOH and foldback for live concerts. I would like to be able to assign my Mains in the control room section to mono output AN 1. I will be using TouchOSC to mix, but in the event anything goes wrong with the wifi connection it would be nice to be able to use the large encoder on the UFX to control the FOH levels. I am usin AN 2 for foldback, so having the Mains assigned to AN 1/2 would mean the encoder controls both the FOH and stage mix levels, which I do not want to do.
Similarly, it would be great to assign "Phones 1"" to AN 2 so I can use the encoder to also control the foldback levels. Even better if I can rename these "control room" names so I can tailor them however works best (e.g., FOH, Foldback #1, Foldback #2)
Is this possible? If not, could such a feature be included in a future update?
While I am making requests, I would like to reiterate on that I (and some others) made previously - to have an option for send levels to follow a specific submix, not not just whichever is highest.
Thank you!
