Topic: UCX: Failing without USB connection and wobbly power socket
just got my new Fireface UCX and I'm amazed about the performance, especially the low latency.
However, there are two issues and I wonder if these should be considerd defects:
1. Often, but not always, the seven-segment display is off after power-on and the encoder knob is not functional.
This frequently happens if power is turned off while there is a USB connection and I wait a couple of minutes before turning power back on.
If I just wait a few seconds before turning power back on, that problem does usually not occur.
The problem can be fixed by disconnecting power again, waiting a couple of minutes, connecting USB and then turning power on.
I assume the seven-segment display should never stay off when powered-on, nor should the encoder be not functional.
I also assume that such behavior should not depend on how long power is disconnected.
Firmware is the latest, v42.
2. The power socket is rather wobbly. When plugged in, I can twist it by approx. 5 degrees in either direction.
That doesn't seem to affect the power connection, but I wonder if this is normal or if there is something loose inside.
I'd appreciate if anyone could shed some light on this based on their own experience.
TIA,
Varta
Re: UCX: Failing without USB connection and wobbly power socket
Such a start-up behavior is not normal. Might be the unit, might be the power supply. The loose connector is 'normal'.
I would prefer to call the connector "flexible", not "loose"... ;-)
Good to know the start-up behavior is not normal, I'll stop trying and testing and rather send the unit in for repair.
I agree with Daniel: "Flexible" sounds a lot more valuable to me than "loose". :-)
Thanks,
Varta
