Topic: babyface worries...
i´m a little worried about my babyface unit!
i noticed a couple of days ago, that i could see lights, from within the unit, from "glitches" on the side and i started wondering if it´s supposed to be like that, or not!?
look att the images, taken from both sides, to know what i mean!
the side with no inputs looks fine to me, but shouln´t the other side look the same?
https://www.dropbox.com/gallery/9045162 … e?h=3ee10c
Re: babyface worries...
can someone who owns a babyface, please just take a quick look at the sides of the unit and compare it to my pictures?
does it look the same?
No, this case should be tightly sealed on both sides.
4 (edited by brynte5 2012-04-25 18:29:12)
ok, that was what i was afraid of:-(
i´ve tried to carefully pull it together, but i was afraid to use much force!
what if i use more force...?
would it come together, or would i risk breaking something...?
maybe it just clicks into place...?
If it does not snap together easily, you should contact the reseller and see what they want to do.
unfortunatley it doesn´t snap together easily:-(
i´ve tried using as much force, as i think is safe!
i contacted my reseller and if i want to send it for service, they´ll just resend it to rme and i won´t be able to record and mix music, for a couple of months (probably):-(
i have no technical or electrical skills, but maybe i could just open up the babyface myself?
how hard can it be?
there are screws under the footpads!
i´ve noticed, cause one footpad is missing!
is this too risky?
As long as the unit works correctly and does not appear loose or so, I would not bother. Mine looks like this, not that much of a difference IMHO.
http://img696.imageshack.us/img696/4383/13061785.jpg
Opening the unit would void warranty.
