Topic: Sound brilliance on Fireface earphones
Hi all,
I am an happy Babyface user since one year but I am definitely having some issues with 'sound brilliance' in earphones. No speakers in my room to make double checks, just a single earphone.
My input is a Yamaha MOX Keyboard. MOX output is connected to Babyface inputs via balanced cables I think my connections are all ok.
I discovered that the sound in the earphones directly connected to MOX is quite more... brilliant than the one coming from Babyface Earphone output. And I am struggling in trying to understand "why".
I checked main things, connections, mixer effects (no effects switched on in TotalMix) and I am sure the volumes are set-up at the same levels during the two tests: after all those verifications, the difference in sound quality remains.
By hearth, what could be the cause? Some specific setting in TotalMix I didn't check that could have reduced the brillance? Some suggestion in how to better connect MOX and Babyface (now I have two balanced male TRS in the MOX and arriving to RME with two TRS/XLR converters and playing on AN1 and AN2 on my TotalMix). What else?
Whatever input / suggestion from your side, even an easy one (I am not an audio technician) is more than welcome !
Thanks !
