Topic: USB 3.0 chipset driver downloads
Hi RME users,
Here are links to the latest USB 3.0 chipset drivers/firmware currently available.
For anyone having performance troubles related to using your RME interface on a USB 3.0 port.
Typically updating to the latest driver and/or firmware for the USB 3.0 controller fixes the issue.
Intel -
Intel® USB 3.0 eXtensible Host Controller Driver
**NEC/RENESAS -
NEC/RENESAS USB3 Controller Driver s and firmware
**Asmedia -
Asmedia USB3 Controller Driver and Firmware
**Etron Technology-
Etron Tech USB 3 Controller Driver
**Make sure to check your motherboard manual or technical Specifications for the correct brand and model chipset.
Important Note:
Make sure to turn off or unplug any USB devices attached to the USB 3.0 ports before doing the driver or firmware update.
Always backup your system and/or create a restore point before updating any device drivers.
Avoid doing any driver updates or installs while in the middle of a recording session......
Thanks Chris
Chris Ludwig
www.facebook.com/RMEAmericas
Twitter @RMEAmericas
Re: USB 3.0 chipset driver downloads
Etron driver download is now at http://www.etron.com/en/products/u3hc.php
Hello , If my motherboard is gigabayte and processor is AMD what i need to download ?
Hi.
I m having digital clipping too.
I have an Imac with intel  3.2 i5 late 2013
Can I run the driver for the usb 3 update on the imac ?
Costas
5
No way.
6 (edited by gallegosruiz637 2017-01-19 05:27:36)
Thanks for your post, it helped me quite a lot
Sorry but i'm lost with my ASUSTeK COMPUTER INC. P8Z77-V LE PLUS Rev X.0x.. Can you help me ? What I have to download ?
Sorry but whats so difficult to do that on your own ? You also didnt provide the OS for which you need it.
I put one example, its simple you should be able to do it.
Google for your board and go to the service area of Asus Website
https://www.asus.com/Motherboards/P8Z77 … _Download/
Choose your OS and then you will see up to around 4 different USB3 drivers:
- 2 newer
- 2 older
for Intel and ASMedia USB3 chips.
Look into device manager or onto your mainboard, what USB3 chips they have mounted on the board.
Most likeky you require 2, I would try the newest which are compatible to your OS.
9 (edited by ronerone 2018-08-03 01:09:34)
Hello all,
i'm quite interested in that post because i just renew my computer in order to finally renew my sound interface.
I currently own a fireface 800 and i'm still balancing between a fireface UFX+ and an antelope orion studio 2017.
I was afraid when reading the fireface UFX+ spec cause it mentions:
"ASMedia - not compatible."
My new mother board being a gigabyte ga-Z370 gaming 7 seems to include only ASMedia USB3.0 controllers.
I know i'd better buy a thunderbolt 3 expansion cards which will fit my motherboard model, but i can't afford everything in the same time.
So, i would like to be sure i can operate a fireface UFX+ on this motherboard USB3 ports with ASMedia controller.
I feel the "ASMedia - not compatible." mention is quite exclusive as i think ASMedia probably builds several references of controllers.
What do you think about that? what is your feedback?
As you propose a link to ASMedia drivers download, i suppose some of you use ASMedia controllers, maybe with UFX+ interfaces?
I'm sorry if some of my sentence are not catchable, i'm french...
Also sorry if this doesn't perfectly match the subject.
I thank you in advance,
Ron.
EDIT: also, maybe i do not only have ASMedia controller for USB3, spec are not so clear...
