Topic: Babyface Driver installation Mac OS 10.6
I'm unable to successfully install the driver for babyface. The babyface interface is plug into the computer.
Computer:
iMac 24" 2.8 GHz Intel Core 2 Duo Mac OS 10.6 4GB 800MHz DDR2  SDRAM
Steps taken:
1. Installed Fireface USB
2. Launched the Fireface USB Flash
3. Error message: No fireface driver or device installed.
What do I do?
Re: Babyface Driver installation Mac OS 10.6
Does the unit light up any LEDs when it's plugged in? Do you use a USB hub or connect direct to the Mac? Did you try a different USB cable yet?
Yes the unit lights up. I don't have a hub. It's connected directly to the computer
Please launch System Profiler (Applications/Utilities) and check to see if the Babyface is listed under USB devices. The Babyface must be plugged in to USB to show up here.
Ok. It's plug in. I don't see the babyface. Would it be listed as babyface?
USB Bus:
  Host Controller Location:    Built-in USB
  Host Controller Driver:    AppleUSBUHCI
  PCI Device ID:    0x2834
  PCI Revision ID:    0x0003
  PCI Vendor ID:    0x8086
  Bus Number:    0x1a
BRCM2046 Hub:
  Product ID:    0x4500
  Vendor ID:    0x0a5c  (Broadcom Corp.)
  Version:     1.00
  Speed:    Up to 12 Mb/sec
  Manufacturer:    Apple Inc.
  Location ID:    0x1a100000 / 2
  Current Available (mA):    500
  Current Required (mA):    0
Bluetooth USB Host Controller:
  Product ID:    0x820f
  Vendor ID:    0x05ac  (Apple Inc.)
  Version:     1.80
  Serial Number:    001EC28B66C7
  Location ID:    0x1a110000 / 4
Yes, it should be listed here. Please try a different USB cable, and check a different computer if possible. If neither is successful, this Babyface may require service.
It's listed there.
Babyface (23299106):
  Product ID:    0x3fc7
  Vendor ID:    0x0424  (SMSC)
  Version:     0.01
  Serial Number:    1793AA1910521C8
  Speed:    Up to 480 Mb/sec
  Manufacturer:    RME
  Location ID:    0xfa200000 / 5
  Current Required (mA):    100
Please explain, I'm missing something...
It looks like it was the cable after all.
