Topic: RME Babyface Dropping Audio
I have come across a new problem with my Babyface. Often times when using the BF simply as iTunes audio playback, the BF will glitch for a second then go silent. iTunes will continue to show that it is playing, and System Preferences shows that the BF is still plugged in. Also, Totalmix does not say that the BF is disconnected, but it is not passing any audio, and the level meters in Totalmix are not moving. If I switch audio outputs in System Preferences and then switch back to the BF, or sometimes if I simply stop iTunes from playing for a couple seconds, and then resume playing, it will start to pass audio again. I am on 10.8.1, and have the latest drives and Firmware for the BF, and I am using the double USB cable that came with the unit, plugged into both USB ports. This has never happend before with any other audio interface, and I have been listening to iTunes for many years smile
Here are some of the console logs that occur when the audio drop out happens - followed by a string of the last command shown here repeating many times over. Any help would be very much appreciated!
9/4/12 2:06:44.925 PM WindowServer[75]: CGXSetWindowListAlpha: Invalid window 0
9/4/12 2:06:44.000 PM kernel[0]: USBF:    1104.335    AppleUSBEHCI[0xffffff8013cb5000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c2a6000 buffHighP 0x0
9/4/12 2:06:44.000 PM kernel[0]: !  outCallback (27) at Time 1104335822us - outFrameNumber: 0x10b90e; systemFrameNumber: 0x10b8b1
9/4/12 2:06:44.000 PM kernel[0]: USBF:    1104.338    AppleUSBEHCI[0xffffff8013cb5000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c2a4000 buffHighP 0x0
9/4/12 2:06:44.000 PM kernel[0]: !  outCallback (28) at Time 1104338297us - outFrameNumber: 0x10b911; systemFrameNumber: 0x10b8b4
9/4/12 2:06:44.000 PM kernel[0]: USBF:    1104.341    AppleUSBEHCI[0xffffff8013cb5000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c2a1000 buffHighP 0x0
2 (edited by togril 2012-09-06 14:51:47)
Re: RME Babyface Dropping Audio
+1
Yep, me too - exactly the same, has done since I bought it.
Babyface + most recent drivers and TotalMix etc.
Plain Vanilla iMac, 2.7 Ghz, 4gig ram, OSX 10.7.4  (it happened in OSX 10.6 as well).
Haven't been that impressed with this occurrence.
Would be good to find out why, seemingly very specific to iTunes. (a buffer ?)
EDIT: With me it is just a drop out, then audio returns. Drop out approximately 2 seconds. This also happens when using Amarra with itunes.
Tog.
The difference between stupidity and genius is that genius has its limits.
~ Albert Einstein
Is there anyone out there that can shed some light on this issue? I've owned the BF for 5 months, and up to this point it has been the most expensive, and BY FAR the most problematic interface I've ever owned. (Even my cheap 7 year old M-Audio Firewire 410 has had less problems).
I am shocked that I am having issues with RME gear, and even more shocked that no one seems to have an answer.
Please help......
Does it happen also with the latest Mac OS driver? 1.76?
best regards
Knut
5 (edited by lemonstre 2012-09-10 23:00:26)
Yes same problem here. It ocurs when the cpu is under high load (iMac i5, driver 1.76), for example rendering or video encoding. Seen this with any audioplayback with iTunes, vlc or plex. In iTunes it helpes to stop the playback, switch to another view (i.e. store) and back to get playback again working. Unplug an start the babyface again also helps.
best regards
andreas
right now again while encoding a videofile with handbrake.
10.09.12 23:53:26,000 kernel[0]: USBF:    31733.828    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3bd000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: !  outCallback (24) at Time 1669057803us - outFrameNumber: 0x1e2fcf4; systemFrameNumber: 0x1e2fc9b
10.09.12 23:53:26,000 kernel[0]: USBF:    31733.828    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3bb000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: !  outCallback (25) at Time 1669057818us - outFrameNumber: 0x1e2fcf7; systemFrameNumber: 0x1e2fc9b
10.09.12 23:53:26,000 kernel[0]: USBF:    31733.831    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3b9000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31733.834    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3b6000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31733.836    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3b4000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 16    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3b1000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 19    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3af000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 22    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3ac000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 25    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3f8000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 28    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3f6000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 32    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3f4000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 34    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3f1000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 37    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3ef000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 40    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3ec000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 43    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3ea000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 46    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3e7000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 49    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3e5000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 52    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3e2000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 55    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3e0000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 58    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3dd000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 61    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3db000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 64    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3d9000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 67    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3d6000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 70    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3d4000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 73    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3d1000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 76    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3cf000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 79    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3cc000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 82    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3ca000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 85    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3c7000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 88    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3c5000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 91    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3c2000 buffHighP 0x0
10.09.12 23:53:26,000 kernel[0]: USBF:    31734. 94    AppleUSBEHCI[0xffffff801e0d1000]::CreateHSIochTransfer - could not find the correct physical page slot for buffP 0x7c3c0000 buffHighP 0x0
10.09.12 23:53:33,787 com.apple.launchd[1]: (com.apple.coremedia.videodecoder[2942]) Exit timeout elapsed (20 seconds). Killing
